Ana içeriğe geç
ProScan PLT7223G Motherboard Replacement
Neye ihtiyacın var
    1. ProScan PLT7223G Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
      • Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. ProScan PLT7223G Motherboard Replacement: adım 2, 1 resimden 1.
      • Use the blue opening tool to pry the tablet open.
      FixBot'a Sor
      Yorum Ekle
    3. ProScan PLT7223G Motherboard Replacement: adım 3, 2 resimden 1. ProScan PLT7223G Motherboard Replacement: adım 3, 2 resimden 2.
      • Remove all yellow tape from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. ProScan PLT7223G Motherboard Replacement: adım 4, 3 resimden 1. ProScan PLT7223G Motherboard Replacement: adım 4, 3 resimden 2. ProScan PLT7223G Motherboard Replacement: adım 4, 3 resimden 3.
      • With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
      • Pay close attention to where each wire goes, so that you reconnect them in the correct order.
      FixBot'a Sor
      Yorum Ekle
    5. ProScan PLT7223G Motherboard Replacement: adım 5, 3 resimden 1. ProScan PLT7223G Motherboard Replacement: adım 5, 3 resimden 2. ProScan PLT7223G Motherboard Replacement: adım 5, 3 resimden 3.
      • Lift all three ZIF connectors to disconnect the ribbon wire.
      FixBot'a Sor
      Yorum Ekle
    6. ProScan PLT7223G Motherboard Replacement: adım 6, 1 resimden 1.
      • Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
      FixBot'a Sor
      Yorum Ekle
    7. ProScan PLT7223G Motherboard Replacement: adım 7, 1 resimden 1.
      • Lift the motherboard off the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
rainbowsend14 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 1,869
