Ana içeriğe geç
ProScan PLT7223G Speakers Replacement
Neye ihtiyacın var
    1. ProScan PLT7223G Speakers Replacement, Speakers: adım 1, 1 resimden 1.
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. ProScan PLT7223G Speakers Replacement: adım 2, 1 resimden 1.
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. ProScan PLT7223G Speakers Replacement: adım 3, 1 resimden 1.
      • Pull back the protective tape from the two wires that connect the speakers to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. ProScan PLT7223G Speakers Replacement: adım 4, 1 resimden 1.
      • Use the soldering tool to remove speaker wires from motherboard.
      • Soldering tool will get hot, handle with care.
      FixBot'a Sor
      Yorum Ekle
    5. ProScan PLT7223G Speakers Replacement: adım 5, 2 resimden 1. ProScan PLT7223G Speakers Replacement: adım 5, 2 resimden 2.
      • If needed use a plastic opening tool to remove speaker from the speaker port on the tablet.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 593
