Ana içeriğe geç
Probook 650 G5 Screen Replacement
Neye ihtiyacın var
  1. Probook 650 G5 Screen Replacement, Turn of Laptop: adım 1, 1 resimden 1.
    • Turn off your Laptop and open the Lid so that you can access all sides of the Monitor
  2. Probook 650 G5 Screen Replacement, Remove Plastic Cover: adım 2, 3 resimden 1. Probook 650 G5 Screen Replacement, Remove Plastic Cover: adım 2, 3 resimden 2. Probook 650 G5 Screen Replacement, Remove Plastic Cover: adım 2, 3 resimden 3.
    • Gently lift the Plastic Cover and move around the Screen doing this
  3. Probook 650 G5 Screen Replacement, Remove Screen: adım 3, 2 resimden 1. Probook 650 G5 Screen Replacement, Remove Screen: adım 3, 2 resimden 2.
    • Remove the 4 Screws and gently Pull the Screen towards you
  4. Probook 650 G5 Screen Replacement, Unplug Screen: adım 4, 3 resimden 1. Probook 650 G5 Screen Replacement, Unplug Screen: adım 4, 3 resimden 2. Probook 650 G5 Screen Replacement, Unplug Screen: adım 4, 3 resimden 3.
    • Lay the Screen gently on the Keyboard of the Laptop and unplug the Display Cable
    • To unplug the cable you need to pull up the adhesive Foil and lift the little Lever which secures the Display Cable
    • Remove the old screen
  5. Probook 650 G5 Screen Replacement, Connect new Screen: adım 5, 1 resimden 1.
    • Place the new Screen on the keyboard and align it with the Display Cable
    • Slide the Cable in the Connector and secure it with the Lever and the adhesive foil
  6. Probook 650 G5 Screen Replacement, Place in the new Screen: adım 6, 2 resimden 1. Probook 650 G5 Screen Replacement, Place in the new Screen: adım 6, 2 resimden 2.
    • Place the new Screen on the Little Plastic nobs and Screw it in using the old srews
    • After that place the Plastic cover on Top and gently Press in around the side
Sonuç
Turn on the Laptop and check if the Screen is Working. If not go through the Steps again
5 farklı kişi bu kılavuzu tamamladı.
Sebbo
241 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 41
Her zaman: 2,662
