Ana içeriğe geç
Processor of why! Replace W253EU
Neye ihtiyacın var
  1. Processor of why! Replace W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 1. Processor of why! Replace W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 2. Processor of why! Replace W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 3.
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Processor of why! Replace W253EU, Access to RAM and CPU from why! W253EU: adım 2, 2 resimden 1. Processor of why! Replace W253EU, Access to RAM and CPU from why! W253EU: adım 2, 2 resimden 2.
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Processor of why! Replace W253EU: adım 3, 3 resimden 1. Processor of why! Replace W253EU: adım 3, 3 resimden 2. Processor of why! Replace W253EU: adım 3, 3 resimden 3.
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Processor of why! Replace W253EU: adım 4, 1 resimden 1.
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
  5. Processor of why! Replace W253EU, processor: adım 5, 3 resimden 1. Processor of why! Replace W253EU, processor: adım 5, 3 resimden 2. Processor of why! Replace W253EU, processor: adım 5, 3 resimden 3.
    • Using the Phillips # 1 screwdriver, unscrew the 3 mounting screws of the processor heat sink.
    • Note position of marker triangle as this will determine the positioning of the processor during replacement.
    • Unlock the coupling system of the processor with a classic screwdriver.
    • Make sure that you do not remove the heat-dissipating paste between the processor and the heat sink, as this is the only way to ensure that the processor is properly cooled.
  6. Processor of why! Replace W253EU: adım 6, 3 resimden 1. Processor of why! Replace W253EU: adım 6, 3 resimden 2. Processor of why! Replace W253EU: adım 6, 3 resimden 3.
    • Carefully disconnect the processor from its holder.
    • Now place the processor aside, taking into account the position of the triangle.
Sonuç
For reassembly, follow the instructions in the reverse order
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
30.884 İtibar
264 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 401
