Giriş
This guide will show how to remove the chassis from a Professional Series PS77401 toaster. The chassis may be damaged from a high height drop and may need replacing to allow even toasting. This guide is not a repair guide and requires a replacement toaster chassis.
Neye ihtiyacın var
Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
Locate the small circuit board attached to the base of the toaster.
To remove the circuit board, pull apart the two side tabs while releasing the middle tab simultaneously.
Pull the circuit board out of the slot.
