Ana içeriğe geç
ProfiMixx 44 Disassembly
    1. ProfiMixx 44 Disassembly, Removing the scrapers: adım 1, 3 resimden 1. ProfiMixx 44 Disassembly, Removing the scrapers: adım 1, 3 resimden 2. ProfiMixx 44 Disassembly, Removing the scrapers: adım 1, 3 resimden 3.
      • Removing the five (TR15) scrapers
      FixBot'a Sor
      Yorum Ekle
    2. ProfiMixx 44 Disassembly, Removing the housing: adım 2, 2 resimden 1. ProfiMixx 44 Disassembly, Removing the housing: adım 2, 2 resimden 2.
      • Removing the first part of the housing
      • Removing the rotary wheel, important pay attention to the black component so that the nose in does not break off (green mark).
      • Removing the second part of the housing
      FixBot'a Sor
      Yorum Ekle
    3. ProfiMixx 44 Disassembly, Assembly of the housing I: adım 3, 3 resimden 1. ProfiMixx 44 Disassembly, Assembly of the housing I: adım 3, 3 resimden 2. ProfiMixx 44 Disassembly, Assembly of the housing I: adım 3, 3 resimden 3.
      • Make sure that the green marked elements are in the right place in both housings, the red element is only available once.
      • Make sure that the two strands run as marked in blue.
      • The white element must be in the rear position. (marked in orange)
      FixBot'a Sor
      Yorum Ekle
    4. ProfiMixx 44 Disassembly, Assembly of the housing II: adım 4, 3 resimden 1. ProfiMixx 44 Disassembly, Assembly of the housing II: adım 4, 3 resimden 2. ProfiMixx 44 Disassembly, Assembly of the housing II: adım 4, 3 resimden 3.
      • Lift the motor-gearbox-unit a little bit upwards so that you can insert the black element with the nose into the hole of the white element. (marked in green)
      • Insert the nose of the black element into the hole of the rotary switch, making sure it is oriented as shown.
      • Gently move the rotary switch so that it fits into the slot in the housing. (marked in blue)
      • Then you can tighten the upper housing part with the five screws (TR15).
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Justus Klingler
531 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 54
Her zaman: 1,925
