Ana içeriğe geç
Projector NEC VT660 Disassembly
Neye ihtiyacın var
  1. Projector NEC VT660 Disassembly, Remove lamp cover: adım 1, 2 resimden 1. Projector NEC VT660 Disassembly, Remove lamp cover: adım 1, 2 resimden 2.
    • Unscrew the screw and remove the cover.
    FixBot'a Sor
    Yorum Ekle
  2. Projector NEC VT660 Disassembly, Remove lamp: adım 2, 2 resimden 1. Projector NEC VT660 Disassembly, Remove lamp: adım 2, 2 resimden 2.
    • Unscrew the two screws that are holding the lamp in place.
    • Pull the lamp out.
    FixBot'a Sor
    Yorum Ekle
  3. Projector NEC VT660 Disassembly, Housing disassembly: adım 3, 3 resimden 1. Projector NEC VT660 Disassembly, Housing disassembly: adım 3, 3 resimden 2. Projector NEC VT660 Disassembly, Housing disassembly: adım 3, 3 resimden 3.
    • Remove 5 screws from the bottom.
    • Remove 1 screw from the back.
    • Slowly lift the upper housing and disconnect the connector.
    • Do not lift the upper housing too quickly as it could damage the connector cable.
    FixBot'a Sor
    Yorum Ekle
  4. Projector NEC VT660 Disassembly, Removing fan: adım 4, 3 resimden 1. Projector NEC VT660 Disassembly, Removing fan: adım 4, 3 resimden 2. Projector NEC VT660 Disassembly, Removing fan: adım 4, 3 resimden 3.
    • After removing the upper housing. Turn the projector to see the fan.
    • Unscrew two screws from each side of the fan holder.
    • Remove the fan from holder by unscrewing the two screws.
    • Carefully take out the fan. Keep an eye on the wires that go through the holder.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Klemen Hodžić
734 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 412
