Ana içeriğe geç
Promowide SP1790 Charging Port Replacement
Neye ihtiyacın var
  1. Promowide SP1790 Charging Port Replacement, Battery Wire: adım 1, 1 resimden 1.
    • Locate the six screws on the back of the speaker.
  2. Promowide SP1790 Charging Port Replacement: adım 2, 1 resimden 1.
    • Unscrew each of the six screws, then set them aside.
  3. Promowide SP1790 Charging Port Replacement: adım 3, 1 resimden 1.
    • Gently remove the back cover of the speaker.
  4. Promowide SP1790 Charging Port Replacement: adım 4, 1 resimden 1.
    • Place the speaker upside down.
    • Remove the battery cover located in the center of the speaker.
  5. Promowide SP1790 Charging Port Replacement: adım 5, 1 resimden 1.
    • Locate and remove the four screws under each of the pads near the power socket.
  6. Promowide SP1790 Charging Port Replacement: adım 6, 1 resimden 1.
    • Gently remove the bottom.
    • Do NOT pull out or damage wires.
  7. Promowide SP1790 Charging Port Replacement: adım 7, 1 resimden 1.
    • Remove the single motherboard screw.
  8. Promowide SP1790 Charging Port Replacement: adım 8, 1 resimden 1.
    • Remove both of the screws holding the power socket to the bottom chassis.
  9. Promowide SP1790 Charging Port Replacement: adım 9, 1 resimden 1.
    • Desolder and remove the old wire.
    • Insert the new wire and solder it into place.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 955
