Ana içeriğe geç
ProntoTec Axius Screen Replacement
Neye ihtiyacın var
    1. ProntoTec Axius Screen Replacement, Screen: adım 1, 1 resimden 1.
      • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
      • Place the tablet face-up on a flat table
      FixBot'a Sor
      Yorum Ekle
    2. ProntoTec Axius Screen Replacement: adım 2, 1 resimden 1.
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      FixBot'a Sor
      Yorum Ekle
    3. ProntoTec Axius Screen Replacement: adım 3, 1 resimden 1.
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      FixBot'a Sor
      Yorum Ekle
    4. ProntoTec Axius Screen Replacement: adım 4, 1 resimden 1.
      • Remove all of the yellow tape that is on the device with the spudger.
      • Be careful not to cut any wires that are under the tapes.
      FixBot'a Sor
      Yorum Ekle
    5. ProntoTec Axius Screen Replacement: adım 5, 2 resimden 1. ProntoTec Axius Screen Replacement: adım 5, 2 resimden 2.
      • Use the flat end of the spudger to gently pry the battery from the back of the screen.
      FixBot'a Sor
      Yorum Ekle
    6. ProntoTec Axius Screen Replacement: adım 6, 2 resimden 1. ProntoTec Axius Screen Replacement: adım 6, 2 resimden 2.
      • Use a spudger to lift all the ribbon cable clamps
      • Detach all three ribbon cables from the clamps
      FixBot'a Sor
      Yorum Ekle
    7. ProntoTec Axius Screen Replacement: adım 7, 3 resimden 1. ProntoTec Axius Screen Replacement: adım 7, 3 resimden 2. ProntoTec Axius Screen Replacement: adım 7, 3 resimden 3.
      • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
      FixBot'a Sor
      Yorum Ekle
    8. ProntoTec Axius Screen Replacement: adım 8, 3 resimden 1. ProntoTec Axius Screen Replacement: adım 8, 3 resimden 2. ProntoTec Axius Screen Replacement: adım 8, 3 resimden 3.
      Bu adımda kullanılan alet:
      Heavy-Duty Spudger
      • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
      • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
      FixBot'a Sor
      Yorum Ekle
    9. ProntoTec Axius Screen Replacement: adım 9, 1 resimden 1.
      • Remove the orange tab from the back of the screen as shown in the picture
      FixBot'a Sor
      Yorum Ekle
    10. ProntoTec Axius Screen Replacement: adım 10, 2 resimden 1. ProntoTec Axius Screen Replacement: adım 10, 2 resimden 2.
      • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Antonio Irons
441 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G3
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 615
