Ana içeriğe geç
Propel Gyro-X Drive Gears Replacement
Neye ihtiyacın var
  1. Propel Gyro-X Drive Gears Replacement, Top Propellor Blades: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Stabilizing links are easy to break. Be gentle when prying them off.
    • Place the tweezers on the sides of the links and pull straight away from the top point of connection.
    FixBot'a Sor
    Yorum Ekle
  2. Propel Gyro-X Drive Gears Replacement: adım 2, 2 resimden 1. Propel Gyro-X Drive Gears Replacement: adım 2, 2 resimden 2.
    • Remove the two 6.0 mm Phillips #00 screws from the rotors.
    FixBot'a Sor
    Yorum Ekle
  3. Propel Gyro-X Drive Gears Replacement: adım 3, 2 resimden 1. Propel Gyro-X Drive Gears Replacement: adım 3, 2 resimden 2.
    • Pull the rotors away from the mounting brackets.
    FixBot'a Sor
    Yorum Ekle
  4. Propel Gyro-X Drive Gears Replacement, Bottom Propellor Blades: adım 4, 1 resimden 1.
    • Remove the two 5.0 mm Phillips #00 screws from the rotors.
    • The blades will fall off when the screws have been removed.
    FixBot'a Sor
    Yorum Ekle
  5. Propel Gyro-X Drive Gears Replacement, Outer Shell: adım 5, 1 resimden 1.
    • Locate the nubs on either side of the helicopter.
    FixBot'a Sor
    Yorum Ekle
  6. Propel Gyro-X Drive Gears Replacement: adım 6, 1 resimden 1.
    • Pull the body shell off of the nubs on both sides.
    FixBot'a Sor
    Yorum Ekle
  7. Propel Gyro-X Drive Gears Replacement: adım 7, 2 resimden 1. Propel Gyro-X Drive Gears Replacement: adım 7, 2 resimden 2.
    • Push the front of the nose back towards the tail of the helicopter.
    • Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
    FixBot'a Sor
    Yorum Ekle
  8. Propel Gyro-X Drive Gears Replacement, Drive Gears: adım 8, 1 resimden 1.
    • Remove the two 8 mm Phillips #00 screws between the motor casing and the body.
    FixBot'a Sor
    Yorum Ekle
  9. Propel Gyro-X Drive Gears Replacement: adım 9, 1 resimden 1.
    • Remove the 4 mm Phillips #00 screw from the tail.
    FixBot'a Sor
    Yorum Ekle
  10. Propel Gyro-X Drive Gears Replacement: adım 10, 3 resimden 1. Propel Gyro-X Drive Gears Replacement: adım 10, 3 resimden 2. Propel Gyro-X Drive Gears Replacement: adım 10, 3 resimden 3.
    • Use your fingers to free the motor casing from the body, by bending the plastic body casing outwards at each of the four nubs.
    • Pull the motor casing upwards from the body.
    • The drive gear will slide out when you lift the motor casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jack Jenner
293 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-2, Forte Spring 2015 Cal Poly, Team 17-2, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 3,534
