Ana içeriğe geç
Propel Gyro-X Drive Gears Replacement
Neye ihtiyacın var
  1. Propel Gyro-X Drive Gears Replacement, Top Propellor Blades: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Stabilizing links are easy to break. Be gentle when prying them off.
    • Place the tweezers on the sides of the links and pull straight away from the top point of connection.
  2. Propel Gyro-X Drive Gears Replacement: adım 2, 2 resimden 1. Propel Gyro-X Drive Gears Replacement: adım 2, 2 resimden 2.
    • Remove the two 6.0 mm Phillips #00 screws from the rotors.
  3. Propel Gyro-X Drive Gears Replacement: adım 3, 2 resimden 1. Propel Gyro-X Drive Gears Replacement: adım 3, 2 resimden 2.
    • Pull the rotors away from the mounting brackets.
  4. Propel Gyro-X Drive Gears Replacement, Bottom Propellor Blades: adım 4, 1 resimden 1.
    • Remove the two 5.0 mm Phillips #00 screws from the rotors.
    • The blades will fall off when the screws have been removed.
  5. Propel Gyro-X Drive Gears Replacement, Outer Shell: adım 5, 1 resimden 1.
    • Locate the nubs on either side of the helicopter.
  6. Propel Gyro-X Drive Gears Replacement: adım 6, 1 resimden 1.
    • Pull the body shell off of the nubs on both sides.
  7. Propel Gyro-X Drive Gears Replacement: adım 7, 2 resimden 1. Propel Gyro-X Drive Gears Replacement: adım 7, 2 resimden 2.
    • Push the front of the nose back towards the tail of the helicopter.
    • Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
  8. Propel Gyro-X Drive Gears Replacement, Drive Gears: adım 8, 1 resimden 1.
    • Remove the two 8 mm Phillips #00 screws between the motor casing and the body.
  9. Propel Gyro-X Drive Gears Replacement: adım 9, 1 resimden 1.
    • Remove the 4 mm Phillips #00 screw from the tail.
  10. Propel Gyro-X Drive Gears Replacement: adım 10, 3 resimden 1. Propel Gyro-X Drive Gears Replacement: adım 10, 3 resimden 2. Propel Gyro-X Drive Gears Replacement: adım 10, 3 resimden 3.
    • Use your fingers to free the motor casing from the body, by bending the plastic body casing outwards at each of the four nubs.
    • Pull the motor casing upwards from the body.
    • The drive gear will slide out when you lift the motor casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jack Jenner
293 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-2, Forte Spring 2015 Cal Poly, Team 17-2, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G2
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 3,050
