Giriş
After rough flights the stabilizer beam may end up getting damaged. Without a working stabilizer beam, the gyro-copter will not fly as it should. The best way to fix this is by replacing the stabilizer beam completely.
Neye ihtiyacın var
Place the tweezers on the sides of the links and pull straight away from the top point of connection.
Bir başkası bu kılavuzu tamamladı.
