Ana içeriğe geç
Proscan Tablet Camera Replacement
Neye ihtiyacın var
    1. Proscan Tablet Camera Replacement, Camera: adım 1, 1 resimden 1.
      • Tools necessary for task. Starting from the left to right Metal Spudyer Plastic opening tool Precision tweezer Point pen tool Driver with bit size J0
      FixBot'a Sor
      Yorum Ekle
    2. Proscan Tablet Camera Replacement: adım 2, 1 resimden 1.
      • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
      FixBot'a Sor
      Yorum Ekle
    3. Proscan Tablet Camera Replacement: adım 3, 1 resimden 1.
      • Once you have finished going around the edges of the tablet, look inside.
      FixBot'a Sor
      Yorum Ekle
    4. Proscan Tablet Camera Replacement: adım 4, 1 resimden 1.
      • You can directly locate and remove the camera component in the corner. Simply unscrew the piece and gently remove the tape wire.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cameron Denny
321 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 630
