Ana içeriğe geç
Protocol Dronium III AP Camera Replacement
Neye ihtiyacın var
  1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: adım 1, 2 resimden 1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: adım 1, 2 resimden 2.
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
    FixBot'a Sor
  2. Protocol Dronium III AP Camera Replacement: adım 2, 1 resimden 1.
    • Remove battery pack from body of drone.
    FixBot'a Sor
  3. Protocol Dronium III AP Camera Replacement: adım 3, 2 resimden 1. Protocol Dronium III AP Camera Replacement: adım 3, 2 resimden 2.
    • Disconnect white connectors between the battery pack and drone.
    FixBot'a Sor
  4. Protocol Dronium III AP Camera Replacement, Camera: adım 4, 1 resimden 1.
    • Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
    FixBot'a Sor
  5. Protocol Dronium III AP Camera Replacement: adım 5, 2 resimden 1. Protocol Dronium III AP Camera Replacement: adım 5, 2 resimden 2.
    • Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
    • Remove the Body Cover.
    FixBot'a Sor
  6. Protocol Dronium III AP Camera Replacement: adım 6, 2 resimden 1. Protocol Dronium III AP Camera Replacement: adım 6, 2 resimden 2.
    • Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
    FixBot'a Sor
  7. Protocol Dronium III AP Camera Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the tape covering the camera with the tweezers.
    FixBot'a Sor
  8. Protocol Dronium III AP Camera Replacement: adım 8, 2 resimden 1. Protocol Dronium III AP Camera Replacement: adım 8, 2 resimden 2.
    • Remove the plastic holding the ribbon cable connector with the tweezers.
    • Be careful with the ribbon cable, it is easy to damage.
    FixBot'a Sor
  9. Protocol Dronium III AP Camera Replacement: adım 9, 1 resimden 1.
    • Move the ribbon cable out of the way with the Spuger.
    FixBot'a Sor
  10. Protocol Dronium III AP Camera Replacement: adım 10, 2 resimden 1. Protocol Dronium III AP Camera Replacement: adım 10, 2 resimden 2.
    • Remove the camera by gently prying it out of the bracket with the spudger.
    FixBot'a Sor
Sonuç
Steven Mooers
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G1, Rose Fall 2017 UW Tacoma, Team S1-G1, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 441
