Ana içeriğe geç
Protocol Dronium One Landing Gear Replacement
Neye ihtiyacın var
  1. Protocol Dronium One Landing Gear Replacement, Landing Gear: adım 1, 2 resimden 1. Protocol Dronium One Landing Gear Replacement, Landing Gear: adım 1, 2 resimden 2.
    • Remove the eight 5.2mm screws located on the drone base using a Phillips 00 screwdriver with a thin end.
  2. Protocol Dronium One Landing Gear Replacement: adım 2, 1 resimden 1.
    • Once all of the screws are off, lift off the top of the drone.
  3. Protocol Dronium One Landing Gear Replacement: adım 3, 2 resimden 1. Protocol Dronium One Landing Gear Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.2mm screws holding the landing gear in place using a Phillips 00 screwdriver and an extension if needed.
  4. Protocol Dronium One Landing Gear Replacement: adım 4, 1 resimden 1.
    • Once the inside screws are removed, carefully pull off the one of the landing gear legs. Repeat this step for the other leg.
Sonuç
Ameth Ramos
537 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Sullivan Spring 2017 USF Tampa, Team S2-G5, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S2G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 449
