Ana içeriğe geç
Protocol Galileo Pinion Gear Replacement
Neye ihtiyacın var
  1. Protocol Galileo Pinion Gear Replacement, Battery: adım 1, 1 resimden 1.
    • Find door on the underside of drone. Open the door.
  2. Protocol Galileo Pinion Gear Replacement: adım 2, 2 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 2, 2 resimden 2.
    • Carefully pull out battery, pulling out wires first.
  3. Protocol Galileo Pinion Gear Replacement: adım 3, 1 resimden 1.
    • Disconnect the connecter.
    • When reconnecting, remember to match up the black wire with the black wire and the red with red.
  4. Protocol Galileo Pinion Gear Replacement, Propeller: adım 4, 2 resimden 1. Protocol Galileo Pinion Gear Replacement, Propeller: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    Satın Al
    • Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
  5. Protocol Galileo Pinion Gear Replacement: adım 5, 1 resimden 1.
    • Twist the white spindle sleeve counter clockwise to align locking pin inside with the opening.
  6. Protocol Galileo Pinion Gear Replacement: adım 6, 1 resimden 1.
    Satın Al
  7. Protocol Galileo Pinion Gear Replacement: adım 7, 1 resimden 1.
    • Pull off white spindle sleeve.
    • Take note of which side of the spindle sleeve is the top.
  8. Protocol Galileo Pinion Gear Replacement: adım 8, 2 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 8, 2 resimden 2.
    • Pull off propeller.
  9. Protocol Galileo Pinion Gear Replacement, Top Shell: adım 9, 3 resimden 1. Protocol Galileo Pinion Gear Replacement, Top Shell: adım 9, 3 resimden 2. Protocol Galileo Pinion Gear Replacement, Top Shell: adım 9, 3 resimden 3.
    • Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
  10. Protocol Galileo Pinion Gear Replacement: adım 10, 2 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 10, 2 resimden 2.
    • Unscrew two 9 mm screws located inside the legs. Repeat the same procedure for the other three legs
  11. Protocol Galileo Pinion Gear Replacement: adım 11, 3 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 11, 3 resimden 2. Protocol Galileo Pinion Gear Replacement: adım 11, 3 resimden 3.
    • Unplug the camera wire.
    • Press the hold release button and slide out the camera module away from the button.
  12. Protocol Galileo Pinion Gear Replacement: adım 12, 2 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 12, 2 resimden 2.
    • Remove the motor protection cover by unscrewing two 9 mm screws using Philips #0. When the screws are off, use your fingers to pull the motor protection cover off. Repeat the procedure for the other three arms.
  13. Protocol Galileo Pinion Gear Replacement: adım 13, 3 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 13, 3 resimden 2. Protocol Galileo Pinion Gear Replacement: adım 13, 3 resimden 3.
    • Unclip the motor cable from the shells housing using two pry tools. Repeat the same procedure for the other three arms.
  14. Protocol Galileo Pinion Gear Replacement: adım 14, 1 resimden 1.
    • Remove 3 9mm screws around the motor housing. Repeat the steps for the three other arms.
  15. Protocol Galileo Pinion Gear Replacement: adım 15, 2 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 15, 2 resimden 2.
    • Remove four 9 mm screws located where the legs originally are placed. (Use a thin head screwdriver)
  16. Protocol Galileo Pinion Gear Replacement: adım 16, 3 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 16, 3 resimden 2. Protocol Galileo Pinion Gear Replacement: adım 16, 3 resimden 3.
    • Cut the yellow strips using a scalpel. Pry open the casing using pry tools working gently around the corners.
  17. Protocol Galileo Pinion Gear Replacement, Pinion Gear: adım 17, 1 resimden 1.
    • Remove the motor assembly from the bottom shell.
  18. Protocol Galileo Pinion Gear Replacement: adım 18, 2 resimden 1. Protocol Galileo Pinion Gear Replacement: adım 18, 2 resimden 2.
    • Slide the pinion gear off of the motor assembly.
Sonuç
Thomas Ramey
301 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 2-3, Rose Winter 2017 UW Tacoma, Team 2-3, Rose Winter 2017 üyesi
UWT-ROSE-W17S2G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 345
