Ana içeriğe geç
Protocol Galileo Stealth Housing Replacement
Neye ihtiyacın var
  1. Protocol Galileo Stealth Housing Replacement, Propeller: adım 1, 1 resimden 1.
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Housing Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Housing Replacement: adım 3, 1 resimden 1.
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Housing Replacement: adım 4, 1 resimden 1.
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Housing Replacement, Housing: adım 5, 2 resimden 1. Protocol Galileo Stealth Housing Replacement, Housing: adım 5, 2 resimden 2.
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Housing Replacement: adım 6, 1 resimden 1.
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
Sonuç
Matthew Selting
453 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 160
