Ana içeriğe geç
Protocol Galileo Stealth Light Emitting Diode (LED) Replacement
Neye ihtiyacın var
  1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: adım 1, 2 resimden 1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: adım 1, 2 resimden 2.
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: adım 2, 1 resimden 1.
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  3. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Light Emitting Diode (LED): adım 3, 1 resimden 1.
    • Remove 6mm Phillips #0 screw from the LED strip.
  4. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: adım 4, 1 resimden 1.
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
  5. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: adım 5, 1 resimden 1.
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
Sonuç
Matthew Selting
453 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 168
