Ana içeriğe geç
Protocol Galileo Stealth Motor Replacement
Neye ihtiyacın var
  1. Protocol Galileo Stealth Motor Replacement, Propeller: adım 1, 1 resimden 1.
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Motor Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Motor Replacement: adım 3, 1 resimden 1.
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Motor Replacement: adım 4, 1 resimden 1.
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Motor Replacement, Housing: adım 5, 2 resimden 1. Protocol Galileo Stealth Motor Replacement, Housing: adım 5, 2 resimden 2.
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Motor Replacement: adım 6, 1 resimden 1.
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  7. Protocol Galileo Stealth Motor Replacement, Motor: adım 7, 2 resimden 1. Protocol Galileo Stealth Motor Replacement, Motor: adım 7, 2 resimden 2.
    • Remove the 3 outer 8mm long Phillips #0 screws from the lower drone housing.
    • Remove the 2 inner 3 mm long Phillips #0 screws from the drone motor.
    • Place screws in a safe place to prevent misplacing them.
  8. Protocol Galileo Stealth Motor Replacement: adım 8, 1 resimden 1.
    • Remove the two 6mm long Phillips #0 screws from the lower motor cover located on the underside of the drone.
    • Place the screws in a safe place to prevent misplacing them.
  9. Protocol Galileo Stealth Motor Replacement: adım 9, 1 resimden 1.
    • Remove the motor cover by lightly pulling it away from the drone.
  10. Protocol Galileo Stealth Motor Replacement: adım 10, 2 resimden 1. Protocol Galileo Stealth Motor Replacement: adım 10, 2 resimden 2.
    • Unclip the wire plug by applying light pressure to the wire plug with the plastic opening tool, and remove the motor.
    • This plug can be a bit difficult to remove, but it does not require much force to remove.
    • Avoid damaging the plug and wires when unclipping wire plug.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Selting
432 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 1,134
