Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will show where to find the battery and how to replace it. If the drone does not have power or the battery is damaged, use this guide to help you.
Neye ihtiyacın var
The battery is accessible through the back of the drone.
Press the tabs on both sides of the white stripe to pull the battery out.
Now that the battery is out, remove the screws starting with the three smaller ones on the top part of the battery.
After this, remove the three on the other side. Make sure to keep track of where each screw came from.
There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
4 farklı kişi bu kılavuzu tamamladı.
5 Yorum
This Kaptur is a $30 drone pretending to be a $150!quad . I have had 2 now 1 & a return and I can say with confidence that this is the worst quad I’ve ever had the displeasure of piloting . Cheap doesn’t do this lemon justice . If you can actually get someone on the phone get your money back there are way better options out there at a lower price point . Even when this pig is airborne it has horrible gps lock and can’t handle any wind over 2mph I believe this was a good idea gone wrong . For you own health and nerves move on do not buy .
You’re obviously a novice pilot. I own 5 and they all work flawlessly and are well made. When it comes to people complaining about Drones, the reason is usually their own fault. They tried to fly in high winds, didn’t calibrate the drone before use, didn’t wait until enough satellites were locked in before take off, used a phone instead of the original transmitter to control the drone or just plain panicked after the drone went into automatic return or they lost the line of sight and orientation etc.
I love this drone, It’s not my first got one before they became popular. I came from flying 450-500 C/P RC Helicopters. If you can fly RC Heli’s or planes you will navigate this like it’s almost hands-free. Seriously that smooth and easy to pilot. For those that have never flown anything RC before then don’t take what I am saying literally because I am referring this to people that actually have flown much harder to navigate RC flyers.
Ok so I do love this drone. I'm just having problems with the recording video or pictures any suggestions
