Ana içeriğe geç
Protocol Kaptur GPS Virtual Reality Lens Replacement
Neye ihtiyacın var
    1. Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: adım 1, 3 resimden 1. Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: adım 1, 3 resimden 2. Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: adım 1, 3 resimden 3.
      • Remove the phone slide from the virtual reality goggles.
      • Take the outside cover off using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Protocol Kaptur GPS Virtual Reality Lens Replacement: adım 2, 3 resimden 1. Protocol Kaptur GPS Virtual Reality Lens Replacement: adım 2, 3 resimden 2. Protocol Kaptur GPS Virtual Reality Lens Replacement: adım 2, 3 resimden 3.
      • Remove each screw from its place.
      • Remove four 6mm Phillips head screws.
      • Remove twelve 7mm Phillips head screws.
      • Pull out each bracket so you can see the full lens case.
      FixBot'a Sor
      Yorum Ekle
    3. Protocol Kaptur GPS Virtual Reality Lens Replacement: adım 3, 3 resimden 1. Protocol Kaptur GPS Virtual Reality Lens Replacement: adım 3, 3 resimden 2. Protocol Kaptur GPS Virtual Reality Lens Replacement: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the adjustable lens lever on top of the virtual reality lens.
      • Using tweezers, you will need to separate the tooth gears and remove them so the lens can fall freely out.
      • Pull the lens case out from the front of the headset.
      FixBot'a Sor
      Yorum Ekle
    4. Protocol Kaptur GPS Virtual Reality Lens Replacement: adım 4, 2 resimden 1. Protocol Kaptur GPS Virtual Reality Lens Replacement: adım 4, 2 resimden 2.
      • With a little force, push the lens from outside in to break the lens out of the case. This will get the lens out.
      • Now replace the lens with a new one and follow the steps in reverse order to put the lens back!
      FixBot'a Sor
      Yorum Ekle
Sonuç
Austin Fedie
168 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team S8-G6, Ogden Spring 2018 UW Stout, Team S8-G6, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G6
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 37
Her zaman: 618
