Ana içeriğe geç
Protocol Slipstream EVO Battery Replacement
Neye ihtiyacın var
  1. Protocol Slipstream EVO Battery Replacement, Battery: adım 1, 2 resimden 1. Protocol Slipstream EVO Battery Replacement, Battery: adım 1, 2 resimden 2.
    • On the bottom of the drone unscrew the screws next to the battery, using the screwdriver provided.
    • The picture shows one of the screws you will be removing, the other screw is directly across from the one being presented.
    • Tip: Removing the screws will loosen the frame of the drone allowing the battery to be removed easier. If you do not want to remove the screws skip to step 2.
  2. Protocol Slipstream EVO Battery Replacement: adım 2, 3 resimden 1. Protocol Slipstream EVO Battery Replacement: adım 2, 3 resimden 2. Protocol Slipstream EVO Battery Replacement: adım 2, 3 resimden 3.
    • Pinch the side of the battery that is already exposed and pull until the battery is fully removed from the drone.
  3. Protocol Slipstream EVO Battery Replacement: adım 3, 3 resimden 1. Protocol Slipstream EVO Battery Replacement: adım 3, 3 resimden 2. Protocol Slipstream EVO Battery Replacement: adım 3, 3 resimden 3.
    • With the replacement battery, insert it where you removed the faulty battery until it fully secured within the drone.
    • Replace screws that were removed earlier if you did not skip step 1.
Sonuç
Michael Dang
301 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 üyesi
UWT-LINER-S17S3G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 601
