Ana içeriğe geç
Protocol Slipstream EVO Propeller Guards Replacement
Neye ihtiyacın var
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: adım 1, 1 resimden 1.
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: adım 2, 2 resimden 1. Protocol Slipstream EVO Propeller Guards Replacement: adım 2, 2 resimden 2.
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: adım 3, 2 resimden 1. Protocol Slipstream EVO Propeller Guards Replacement: adım 3, 2 resimden 2.
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
Sonuç
Michael Dang
301 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 üyesi
UWT-LINER-S17S3G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 236
