Ana içeriğe geç
Protocol Slipstream WiFi Camera Replacement
Neye ihtiyacın var
  1. Protocol Slipstream WiFi Camera Replacement, Camera: adım 1, 2 resimden 1. Protocol Slipstream WiFi Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Remove the four 5.5 mm Phillips #00 screws that hold the lower canopy to the upper canopy.
    • Gently pull the lower canopy up and towards the back of the drone. The lower canopy will still be attached to the upper canopy by 3 wires. Just set the lower canopy aside and continue with the repair.
    • Be very careful when pulling the lower canopy apart from the upper canopy. There are 3 wires that will still be attached between the lower and upper canopies.
    FixBot'a Sor
    Yorum Ekle
  2. Protocol Slipstream WiFi Camera Replacement: adım 2, 2 resimden 1. Protocol Slipstream WiFi Camera Replacement: adım 2, 2 resimden 2.
    • Remove the four 5.5 mm Phillips #00 screws that holds the battery tray to the lower canopy.
    • Once the four 5.5 mm Philips #00 screws are removed gently pull on the battery tray to separate it from the lower canopy.
    FixBot'a Sor
    Yorum Ekle
  3. Protocol Slipstream WiFi Camera Replacement: adım 3, 1 resimden 1.
    • Use a spudger to gently pry around the outside edge of the camera to remove the camera from its mounting hole.
    • Be careful when removing the camera from its mounting hole as there is a small ribbon wire that connects it to the computer.
    • The camera and computer assembly will now be free to move. Move the lower canopy out of the way for now.
    FixBot'a Sor
    Yorum Ekle
  4. Protocol Slipstream WiFi Camera Replacement: adım 4, 3 resimden 1. Protocol Slipstream WiFi Camera Replacement: adım 4, 3 resimden 2. Protocol Slipstream WiFi Camera Replacement: adım 4, 3 resimden 3.
    • Use the flat side of the spudger and push the 2 tabs on either side of the camera connection on the computer and push the tabs towards the front of the drone (away from the computer).
    • Make sure both tabs are all the way out otherwise the ribbon wire for the camera will not be free and you can damage the wire by pulling on it.
    • Now remove the camera ribbon wire from the camera connection on the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 450
