Ana içeriğe geç
Protocol Slipstream WiFi Propeller Replacement
Neye ihtiyacın var
  1. Protocol Slipstream WiFi Propeller Replacement, Propeller: adım 1, 1 resimden 1.
    • Remove the 4.5 mm Philips #00 screw that holds the propeller in place.
    FixBot'a Sor
  2. Protocol Slipstream WiFi Propeller Replacement: adım 2, 1 resimden 1.
    • Lift the propeller off the device
    • Note: When sliding on the new propeller, make sure to align the groove on the propeller with the shaft of the gear. If aligned correctly the propeller should slide on smoothly.
    • There are two different propellers that go on the device. Each propeller has a 3 or 4 written on it. Be sure to replace the propeller with a new propeller with the matching number.
    FixBot'a Sor
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 53
Her zaman: 402
