Ana içeriğe geç
Protocol Vento Motor Replacement
Neye ihtiyacın var
    1. Protocol Vento Motor Replacement, Battery: adım 1, 1 resimden 1.
      • Grasp the tail end of the drone where the lip of the battery protrudes.
      FixBot'a Sor
      Yorum Ekle
    2. Protocol Vento Motor Replacement: adım 2, 1 resimden 1.
      • Pull away from the drone to remove the battery.
      • Do not attempt any repairs or replacements before removing the battery from the drone.
      FixBot'a Sor
      Yorum Ekle
    1. Protocol Vento Motor Replacement, Propeller: adım 3, 1 resimden 1.
      • Place a prying tool under the base of the propeller.
      FixBot'a Sor
      Yorum Ekle
    2. Protocol Vento Motor Replacement: adım 4, 2 resimden 1. Protocol Vento Motor Replacement: adım 4, 2 resimden 2.
      • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
      FixBot'a Sor
      Yorum Ekle
    1. Protocol Vento Motor Replacement, Motor: adım 5, 1 resimden 1.
      • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
      FixBot'a Sor
      Yorum Ekle
    2. Protocol Vento Motor Replacement: adım 6, 2 resimden 1. Protocol Vento Motor Replacement: adım 6, 2 resimden 2.
      • Hold the base of the arm while gently pulling the motor cover away from the arm.
      • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
      FixBot'a Sor
      Yorum Ekle
    3. Protocol Vento Motor Replacement: adım 7, 2 resimden 1. Protocol Vento Motor Replacement: adım 7, 2 resimden 2.
      • Gently pull the motor out from the plastic cover.
      • Do not squeeze or pull too hard, as to not damage the motor connection.
      FixBot'a Sor
      Yorum Ekle
    4. Protocol Vento Motor Replacement: adım 8, 2 resimden 1. Protocol Vento Motor Replacement: adım 8, 2 resimden 2.
      Bu adımda kullanılan alet:
      • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
      • Grasp the clip’s edges with a pair of tweezers and pull outward.
      • Do not pull directly on the wires, as to not separate the wires from the clip.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Maria Larcomb
926 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Spring 2018 USF Tampa, Team S1-G2, Leahy Spring 2018 üyesi
USFT-LEAHY-S18S1G2
4 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Please send me motor description
suresh virji - Yanıt Paylaş
send me protocol vento motor
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 1,041
