Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Grasp the tail end of the drone where the lip of the battery protrudes.
To get into the drone, twelve total screws need to be removed:
Ten 5.7mm Phillips #000 screws from the bottom of the drone body.
Two 4.5mm Phillips #000 screws at the front of the drone.
Flip the drone over and lift off the top plastic shell of the drone.
Remove the foam adhesive pad located on the Wi-Fi transmitter board.
Pry the gold Wi-Fi antenna connector, located under the previously removed foam pad, away from the Wi-Fi transmitter board to disconnect it.
Remove the two 3.8mm Phillips #000 screws from the Wi-Fi transmitter board.
Disconnect the white clip that connects the four colored wires (black, orange, red, blue) to the motherboard.
Gently pull the black wedge away from the main board until it shifts to a stop. You will feel it slide out, then stop.
Lightly pull the ribbon cable away from the connector.
3 farklı kişi bu kılavuzu tamamladı.
