Ana içeriğe geç
Protocol Videodrone AP Battery Wiring Replacement
Neye ihtiyacın var
    1. Protocol Videodrone AP Battery Wiring  Replacement, Battery Wiring: adım 1, 1 resimden 1.
      • Make sure the drone is turned off
      FixBot'a Sor
      Yorum Ekle
    2. Protocol Videodrone AP Battery Wiring  Replacement: adım 2, 1 resimden 1.
      • Open the hatch and carefully pull out the battery to expose the cable connection
      FixBot'a Sor
      Yorum Ekle
    3. Protocol Videodrone AP Battery Wiring  Replacement: adım 3, 2 resimden 1. Protocol Videodrone AP Battery Wiring  Replacement: adım 3, 2 resimden 2.
      • Carefully pull apart the cable connection
      FixBot'a Sor
      Yorum Ekle
    4. Protocol Videodrone AP Battery Wiring  Replacement: adım 4, 2 resimden 1. Protocol Videodrone AP Battery Wiring  Replacement: adım 4, 2 resimden 2.
      • Unscrew the 4 screws from the bottom of the drone.
      • Unscrew the 8 screws connecting the propeller guards to the drone
      • Unscrew the four propeller screws.
      • One screw is hidden behind the screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Protocol Videodrone AP Battery Wiring  Replacement: adım 5, 1 resimden 1.
      • Carefully remove faulty battery wiring from the drone
      FixBot'a Sor
      Yorum Ekle
    6. Protocol Videodrone AP Battery Wiring  Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Feed through opening using tweezers to grasp the wire and carefully pull through.
      FixBot'a Sor
      Yorum Ekle
    7. Protocol Videodrone AP Battery Wiring  Replacement: adım 7, 1 resimden 1.
      • Use the soldering iron to solder new wires to mother board. CAUTION: Soldering iron may get hot and cause minor burns if handled improperly.
      • Use this guide for how to solder: https://www.youtube.com/watch?v=QKbJxytE...
      FixBot'a Sor
      Yorum Ekle
    8. Protocol Videodrone AP Battery Wiring  Replacement: adım 8, 1 resimden 1.
      • Reattach the battery and test for power by turning on the drone and look for the 4 LEDs turn on.
      FixBot'a Sor
      Yorum Ekle
Sonuç
All Done!
Bir başkası bu kılavuzu tamamladı.
Serge
340 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Passmore Fall 2017 USF Tampa, Team S2-G1, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G1
4 Üyeler
3Kılavuz Yorumları
Great explanation. Just wondering where to get the replacement piece. My drone has the black wire hanging by a single strand just outside the white connector. The red wire is in tact but I would need the whole part that attaches to the board and extends outside the drone to connect the battery to. Thanks
yasureok - Yanıt Paylaş
Was wondering i think its charging the blue light flashes when plugged in but wont turn on. Wires look brand new
Michael Landry - Yanıt Paylaş
I’m wondering the same thing, mine lights up blue when charging, wires look good but still no action.
Ryann Hunter - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 2,176
