Ana içeriğe geç
Pulsar Xlite V2 Wireless Battery Replacement
Neye ihtiyacın var
  1. Pulsar Xlite V2 Wireless Battery Replacement, Battery: adım 1, 2 resimden 1. Pulsar Xlite V2 Wireless Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Disassembly is the first step, which requires something thin like a mini pry bar or even your fingernails, specifically to remove the lower mouse skate at the flat bottom side of the mouse.
  2. Pulsar Xlite V2 Wireless Battery Replacement: adım 2, 1 resimden 1.
    • After removing the mouse skate, there are screws for which the Phillips screwdriver is used to unscrew and detach the bottom layer of the mouse.
  3. Pulsar Xlite V2 Wireless Battery Replacement: adım 3, 3 resimden 1. Pulsar Xlite V2 Wireless Battery Replacement: adım 3, 3 resimden 2. Pulsar Xlite V2 Wireless Battery Replacement: adım 3, 3 resimden 3.
    • To separate the bottom and top layer, begin lifting the bottom half of the mouse.
    • Next, apply some pressure by pushing the slighted lifted top layer towards the hinges seen in the second picture. Then, the entire top layer can be lifted off.
  4. Pulsar Xlite V2 Wireless Battery Replacement: adım 4, 3 resimden 1. Pulsar Xlite V2 Wireless Battery Replacement: adım 4, 3 resimden 2. Pulsar Xlite V2 Wireless Battery Replacement: adım 4, 3 resimden 3.
    • The battery is located towards the lower end of the mouse in a rectangular housing, where the palm would usually rest above, along with wires connecting to its white 3-pin slot towards the opposite side of the battery location. Remove the connector, located in the second picture by the red circle, from its slot and the battery.
    • The new battery can now be attached in the opposite manner as the detached battery by connecting the 3-pin connector in its slot.
    • The connector pin can initally be tightly secured meaning you might require slightly more force than you expect to detach the pin. Be wary of the surrounding parts near the pin as to not damage the rest of the mouse.
    • Reassembly is simply steps 2 through 4 in reverse order.
    • However, when finishing with step 2, the bottom mouse skate can be easily applied without the user of fingernails or the mini pry bar.
Sonuç
Now that you've successfully replaced the battery, enjoy the renewed efficiency and responsiveness of your Pulsar Xlite V2 Wireless mouse. Happy computing!
Bir başkası bu kılavuzu tamamladı.
Darrin Du
148 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 12-3, Ribeiro Fall 2023 CSU Los Angeles, Team 12-3, Ribeiro Fall 2023 üyesi
CSULA-RIBEIRO-F23S12G3
2 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 38
Son 30 gün: 137
Her zaman: 883
