Ana içeriğe geç
Puritan Bennett 540 Alarm Resetting Technique
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
  1. Puritan Bennett 540 Alarm Resetting Technique, Puritan Bennett 540 Alarm Resetting Technique: adım 1, 1 resimden 1.
    • Press the MENU Key to access the Alarm Settings Menu.
  2. Puritan Bennett 540 Alarm Resetting Technique: adım 2, 2 resimden 1. Puritan Bennett 540 Alarm Resetting Technique: adım 2, 2 resimden 2.
    • Press the down arrow key to position the cursor on the “Alarm Logs” line, if this is not already the case.
  3. Puritan Bennett 540 Alarm Resetting Technique: adım 3, 1 resimden 1.
    • Press the Enter key to confirm the selection of the Alarm Menu.
  4. Puritan Bennett 540 Alarm Resetting Technique: adım 4, 2 resimden 1. Puritan Bennett 540 Alarm Resetting Technique: adım 4, 2 resimden 2.
    • Press the up arrow key to position the cursor on the “Reactivate Paused Alarm” line. The following graphic shows the resulting display.
  5. Puritan Bennett 540 Alarm Resetting Technique: adım 5, 3 resimden 1. Puritan Bennett 540 Alarm Resetting Technique: adım 5, 3 resimden 2. Puritan Bennett 540 Alarm Resetting Technique: adım 5, 3 resimden 3.
    • Press the Enter key for at least three (3) seconds. The following events occur:
    • A “beep” sounds.
    • An audible alarm sounds.
    • An alarm indicator illuminates.
    • The messages of all active alarms are displayed in a loop in the Ventilation and Alarm menus.
    • The Audio Paused symbol disappears (if it was displayed).
    • The Alarm Paused symbol disappears.
Sonuç
There is no need to reassemble the device, but if the condition persists you can try resetting the audio again.
kerribyrne
267 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G7, Paton Spring 2020 Cal Poly, Team S7-G7, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G7
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 111
