Ana içeriğe geç
Puritan Bennett 540 Battery Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Puritan Bennett 540 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Place the ventilator on a work table.
    FixBot'a Sor
    Yorum Ekle
  2. Puritan Bennett 540 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the three screws (item one) securing the battery cover with a Torx T10 screwdriver. These screws consist of two Torx head screws on the back panel and one Torx head screw on the bottom of the ventilator, as shown (depends on the version of the device).
    FixBot'a Sor
    Yorum Ekle
  3. Puritan Bennett 540 Battery Replacement: adım 3, 1 resimden 1.
    • Slide the battery cover ( item 2) off by pulling it towards the back of the ventilator.
    FixBot'a Sor
    Yorum Ekle
  4. Puritan Bennett 540 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the old battery ( item 3) from the battery cover.
    FixBot'a Sor
    Yorum Ekle
  5. Puritan Bennett 540 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the replacement battery from its package and install it into the battery cover. Make sure you remove the pull tabs (if they are present) from the battery’s contacts.
    FixBot'a Sor
    Yorum Ekle
  6. Puritan Bennett 540 Battery Replacement: adım 6, 1 resimden 1.
    • Place the battery cover containing the replacement battery back onto its slide rails within the ventilator.
    • Note: Push on the battery cover from the rear towards the front when tightening screws to make sure nothing breaks.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order
Nina Aliamus
133 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G7, Paton Spring 2020 Cal Poly, Team S7-G7, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G7
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 332
