Ana içeriğe geç
Puritan Bennett 840 Oxygen Sensor Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
  1. Puritan Bennett 840 Oxygen Sensor Replacement, Oxygen Sensor: adım 1, 1 resimden 1.
    • Locate the flexible oxygen sensor access cover on the top edge of the cabinet and firmly push the center of the lower flap of the access cover until the lower flap is dislodged from the cabinet.
  2. Puritan Bennett 840 Oxygen Sensor Replacement: adım 2, 1 resimden 1.
    • Pinch the bottom and top flaps of the access cover firmly together and pull the access cover away from the cabinet to remove.
  3. Puritan Bennett 840 Oxygen Sensor Replacement: adım 3, 1 resimden 1.
    • Press the small white release tab away from the sensor cable connector to release the sensor cable connector.
    • While continually pressing the release tab, gently pull the connector from the oxygen sensor.
  4. Puritan Bennett 840 Oxygen Sensor Replacement: adım 4, 1 resimden 1.
    • Unscrew (counter-clockwise) and remove the oxygen sensor.
  5. Puritan Bennett 840 Oxygen Sensor Replacement: adım 5, 1 resimden 1.
    • Open the replacement oxygen sensor and O-ring. Make sure the O-ring is at the threaded base of the oxygen sensor, and screw (clockwise) until snug.
Sonuç
To reassemble your device, follow these instructions in reverse order. Calibrate new oxygen sensor by pressing 100% O2/ CAL 2 min key. Run an SST to check the system before using the ventilator on a patient.
2 farklı kişi bu kılavuzu tamamladı.
Gabrielle Reyes
154 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G4, Paton Spring 2020 Cal Poly, Team S7-G4, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G4
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 52
Her zaman: 2,447
