Ana içeriğe geç
Purse Strap Replacement
Neye ihtiyacın var
    1. Purse Strap Replacement, Strap: adım 1, 1 resimden 1.
      • Find a replacement strap or a long, thin piece of fabric you want to use for your purse strap.
      FixBot'a Sor
      Yorum Ekle
    2. Purse Strap Replacement: adım 2, 1 resimden 1.
      • Make sure the strap is the correct length for your carrying preference. For example: crossbody, one-shoulder, crook of the elbow, etc.
      • Measurements will vary depending on preference.
      • For this project, we will be sewing a one-shoulder strap.
      FixBot'a Sor
      Yorum Ekle
    3. Purse Strap Replacement: adım 3, 1 resimden 1.
      • Put the strap through the handle attachments.
      • Fold the end over.
      • There should be about 1/2 inch to 1 inch room for sewing.
      • Note: once the strap's end is folded over, make sure there is enough strap between each handle attachment for you to carry the bag.
      • Get your needle out and thread it with your preference of colored thread. We have used black.
      FixBot'a Sor
      Yorum Ekle
    4. Purse Strap Replacement: adım 4, 2 resimden 1. Purse Strap Replacement: adım 4, 2 resimden 2.
      • Fold the strap so there is a half-inch between the stitching line and the handle attachment.
      • Sewing
      • Start on one edge and push the needle through both piece of strap.
      • Once the bit of thread is pulled through, go through the strap again, this time a pinch to the side of where you came up.
      • Repeat this until you have sewed a stitch across the entire width of the strap.
      • After reaching the opposite end, pull the needle through, bringing up as much excess thread as it allows. Note: do not pull too hard or the thread will rip.
      • Tie a knot at the end, keeping the knot close to the base of the thread. Repeat until you believe the knot is strong enough to hold.
      FixBot'a Sor
      Yorum Ekle
    5. Purse Strap Replacement: adım 5, 1 resimden 1.
      • After you reach the other side of the strap's width, sew backwards on top of the existing seams for a locking stitch.
      • Cut excess string.
      FixBot'a Sor
      Yorum Ekle
    6. Purse Strap Replacement: adım 6, 1 resimden 1.
      • Repeat steps 3-5 on the opposite handle attachment.
      FixBot'a Sor
      Yorum Ekle
    7. Purse Strap Replacement: adım 7, 1 resimden 1.
      • After repeating the steps, each side of your strap should be sewed onto the handle attachments.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Make sure the stitches are secure by gently tugging on the strap. If it does not come un-stitched, then you are finished with your repair.
Bir başkası bu kılavuzu tamamladı.
Annie Chapman
112 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 55
Her zaman: 2,622
