Ana içeriğe geç
Putting On A Transparent Shell On Flipper Zero
Neye ihtiyacın var
  1. Putting On A Transparent Shell On Flipper Zero, Take Out The SD Card: adım 1, 1 resimden 1.
    • An Easy Way To Get The SD Card Out Is To Grip It With Your Fingernails.
  2. Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: adım 2, 3 resimden 1. Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: adım 2, 3 resimden 2. Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: adım 2, 3 resimden 3.
    • Use A PH0 Screwdriver To Open/Remove The Back Part Of The Shell.
    • Be Careful, The Screws Strip Easily. One Way To Combat This Is To Press Down On The Screw While Unscrewing It.
  3. Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: adım 3, 3 resimden 1. Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: adım 3, 3 resimden 2. Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: adım 3, 3 resimden 3.
    • Using Your Fingernail, Spudger, Guitar Pick, Or Any Other Prying Tool, Take Off The Back Shell.
  4. Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: adım 4, 3 resimden 1. Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: adım 4, 3 resimden 2. Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: adım 4, 3 resimden 3.
    • Using Your PH0 Screwdriver Unscrew The Two Short Screws Holding The Internals Down To The Shell.
    • Be Careful With The iButton Pins, They Break Off Very Easily.
  5. Putting On A Transparent Shell On Flipper Zero, Transfer The Flipper's Internals To The New Shell: adım 5, 2 resimden 1. Putting On A Transparent Shell On Flipper Zero, Transfer The Flipper's Internals To The New Shell: adım 5, 2 resimden 2.
    • Put Your Flipper's Internals Into The New Shell.
    • Screw The Three Short Screws Back Into Place.
    • Do Not Make The Screws Too Tight As The Threads On The New Transparent Board Will Strip Because It Is 3D Printed.
  6. Putting On A Transparent Shell On Flipper Zero, Take The NFC Board Off The Back Shell: adım 6, 2 resimden 1. Putting On A Transparent Shell On Flipper Zero, Take The NFC Board Off The Back Shell: adım 6, 2 resimden 2.
    • Using Your, Spudger, Guitar Pick, Flathead Screwdriver, Or Any Other Prying Tool, Take Off The NFC Board
    • Do Not Use Your Fingernails To Take Off The NFC Board!
  7. Putting On A Transparent Shell On Flipper Zero, Put The NFC Board Onto The New Transparent Back Shell: adım 7, 1 resimden 1.
    • The NFC Board Should Look Like How It Is In The Picture, If It Doesn't Look Like The Picture Reapply The NFC Board.
  8. Putting On A Transparent Shell On Flipper Zero, Combine The Two Shells: adım 8, 2 resimden 1. Putting On A Transparent Shell On Flipper Zero, Combine The Two Shells: adım 8, 2 resimden 2.
    • Put The Two Shells Together And Then Insert The Four Long Screws Into The Screw Holes And Tighten Them.
  9. Putting On A Transparent Shell On Flipper Zero, YA DONE!: adım 9, 2 resimden 1. Putting On A Transparent Shell On Flipper Zero, YA DONE!: adım 9, 2 resimden 2.
    • You Have Just Assembled Yourself A Transparent Flipper Zero, Nice Work!
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Kaeden
337 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 48
Son 30 gün: 157
Her zaman: 1,707
