Ana içeriğe geç
Pyrus PY21S03211 Display Screen Replacement
Neye ihtiyacın var
  1. Pyrus PY21S03211 Display Screen Replacement, Display Screen: adım 1, 3 resimden 1. Pyrus PY21S03211 Display Screen Replacement, Display Screen: adım 1, 3 resimden 2. Pyrus PY21S03211 Display Screen Replacement, Display Screen: adım 1, 3 resimden 3.
    • Find the tab at the bottom covering the battery compartment.
    • Pull back the tab to reveal the battery compartment.
  2. Pyrus PY21S03211 Display Screen Replacement: adım 2, 1 resimden 1.
    • To remove the battery from the device, pull back the tab holding it in place and then remove the battery.
  3. Pyrus PY21S03211 Display Screen Replacement: adım 3, 2 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Open up the display screen.
    • Remove the tab covering the battery compartment using a pair of tweezers.
  4. Pyrus PY21S03211 Display Screen Replacement: adım 4, 2 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 4, 2 resimden 2.
    • Use a #00 screwdriver to remove all six 4 mm screws from the side of the device.
  5. Pyrus PY21S03211 Display Screen Replacement: adım 5, 2 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 5, 2 resimden 2.
    • To remove the side face of the device, you can use a plastic pick to gently pry it off. Be careful while doing so to avoid potential device damage.
  6. Pyrus PY21S03211 Display Screen Replacement: adım 6, 1 resimden 1.
    • Carefully open the side face. Keep the side face close to the body of the device to avoid pulling on the white wires.
  7. Pyrus PY21S03211 Display Screen Replacement: adım 7, 2 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 7, 2 resimden 2.
    • To remove the side face completely, locate the big white connector.
    • Lift the grey lip using tweezers. Then, carefully take out the white connector.
  8. Pyrus PY21S03211 Display Screen Replacement: adım 8, 3 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 8, 3 resimden 2. Pyrus PY21S03211 Display Screen Replacement: adım 8, 3 resimden 3.
    • Set the device down with the screen facing towards you.
    • Remove the four 4mm silver screws from the back of the side face.
  9. Pyrus PY21S03211 Display Screen Replacement: adım 9, 2 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 9, 2 resimden 2.
    • Use tweezers to remove the small shiny black plastic corner piece from the side.
  10. Pyrus PY21S03211 Display Screen Replacement: adım 10, 3 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 10, 3 resimden 2. Pyrus PY21S03211 Display Screen Replacement: adım 10, 3 resimden 3.
    • Twist the screen to the side to reveal two black 4mm screws.
    • Remove screws from both sides of the screen.
  11. Pyrus PY21S03211 Display Screen Replacement: adım 11, 2 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 11, 2 resimden 2.
    • Use a plastic pick to pry off the backside of the screen.
  12. Pyrus PY21S03211 Display Screen Replacement: adım 12, 2 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 12, 2 resimden 2.
    • Use tweezers to open the gray lip of the large white connector and carefully remove it.
  13. Pyrus PY21S03211 Display Screen Replacement: adım 13, 1 resimden 1.
    • Find two 4mm silver screws at the base of the screen and remove them.
  14. Pyrus PY21S03211 Display Screen Replacement: adım 14, 1 resimden 1.
    • To remove the gold transparent connector, gently flip open the grey lip using tweezers.
  15. Pyrus PY21S03211 Display Screen Replacement: adım 15, 1 resimden 1.
    • Locate the two 4mm black screw on top of the display screen and remove them.
  16. Pyrus PY21S03211 Display Screen Replacement: adım 16, 2 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 16, 2 resimden 2.
    • Remove green board carefully.
  17. Pyrus PY21S03211 Display Screen Replacement: adım 17, 3 resimden 1. Pyrus PY21S03211 Display Screen Replacement: adım 17, 3 resimden 2. Pyrus PY21S03211 Display Screen Replacement: adım 17, 3 resimden 3.
    • Gently remove the white display screen with your hands.
  18. Pyrus PY21S03211 Display Screen Replacement: adım 18, 1 resimden 1.
    • Carefully insert the replacement screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 460
