Ana içeriğe geç
QFX IT-437 Battery Replacement
Neye ihtiyacın var
  1. QFX IT-437 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Battery Replacement: adım 2, 2 resimden 1. QFX IT-437 Battery Replacement: adım 2, 2 resimden 2.
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the tape connecting the battery to the motherboard.
    • Save the tape in good condition for the replacement so the wires do not get stuck in the case.
  4. QFX IT-437 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the black tape attaching the wires to the battery.
  5. QFX IT-437 Battery Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
    • The removed wires will have to be soldered back on to the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Douglas
482 İtibar
4 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 üyesi
PHSC-PRINCE-W15S5G2
6 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 399
