Ana içeriğe geç
QFX IT-437 Camera Assembly Replacement
Neye ihtiyacın var
  1. QFX IT-437 Camera Assembly Replacement, Camera Assembly: adım 1, 1 resimden 1.
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Camera Assembly Replacement: adım 2, 2 resimden 1. QFX IT-437 Camera Assembly Replacement: adım 2, 2 resimden 2.
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Camera Assembly Replacement: adım 3, 1 resimden 1.
    • Use the spudger to unhinge the camera from its socket.
  4. QFX IT-437 Camera Assembly Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening pick and the Phillips screwdriver to remove the camera from its soldering on the motherboard, and set it aside to be replaced.
Sonuç
Douglas
482 İtibar
4 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 üyesi
PHSC-PRINCE-W15S5G2
6 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 124
