Ana içeriğe geç
QFX IT-437 Motherboard Replacement
Neye ihtiyacın var
  1. QFX IT-437 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Motherboard Replacement: adım 2, 2 resimden 1. QFX IT-437 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Motherboard Replacement: adım 3, 1 resimden 1.
    • In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
  4. QFX IT-437 Motherboard Replacement: adım 4, 1 resimden 1.
    • Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
    • Be careful not to rip or damage the tape or else new tape will have to be used for the new motherboard.
  5. QFX IT-437 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use the spudger to remove the ribbon.
    • Avoid using too much force here or else the ribbon can be ripped.
  6. QFX IT-437 Motherboard Replacement: adım 6, 1 resimden 1.
    • Use the spudger in the top corner of the tablet and lift the camera up.
  7. QFX IT-437 Motherboard Replacement: adım 7, 1 resimden 1.
    • Lift the tape over the wires that are holding them to the tablet insulation.
  8. QFX IT-437 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull out the motherboard and set it aside.
    • The wires must be soldered back on to the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Douglas
482 İtibar
4 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-2, Prince Winter 2015 Pasco Hernando, Team 5-2, Prince Winter 2015 üyesi
PHSC-PRINCE-W15S5G2
6 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 246
