Ana içeriğe geç
QSEW QS-1201 Needle Replacement
Neye ihtiyacın var
  1. QSEW QS-1201 Needle Replacement, Needle: adım 1, 3 resimden 1. QSEW QS-1201 Needle Replacement, Needle: adım 1, 3 resimden 2. QSEW QS-1201 Needle Replacement, Needle: adım 1, 3 resimden 3.
    • Power off your machine and unplug it from the outlet.
    • This will prevent accidental activation and injury, even for experts!
  2. QSEW QS-1201 Needle Replacement: adım 2, 2 resimden 1. QSEW QS-1201 Needle Replacement: adım 2, 2 resimden 2.
    • Have a close look at the difference between the broken needle ( left ) and the brand-new needle ( right ).
  3. QSEW QS-1201 Needle Replacement: adım 3, 3 resimden 1. QSEW QS-1201 Needle Replacement: adım 3, 3 resimden 2. QSEW QS-1201 Needle Replacement: adım 3, 3 resimden 3.
    • Locate the needle holder with the broken needle.
  4. QSEW QS-1201 Needle Replacement: adım 4, 3 resimden 1. QSEW QS-1201 Needle Replacement: adım 4, 3 resimden 2. QSEW QS-1201 Needle Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Satın Al
  5. QSEW QS-1201 Needle Replacement: adım 5, 3 resimden 1. QSEW QS-1201 Needle Replacement: adım 5, 3 resimden 2. QSEW QS-1201 Needle Replacement: adım 5, 3 resimden 3.
    • Gently secure the needle with the needle nose pliers.
    • With a tight grip, pull down to remove the needle.
  6. QSEW QS-1201 Needle Replacement: adım 6, 3 resimden 1. QSEW QS-1201 Needle Replacement: adım 6, 3 resimden 2. QSEW QS-1201 Needle Replacement: adım 6, 3 resimden 3.
    • Discard the broken needle in a safe place.
    • By doing so, you ensure that no one gets injured when dealing with the trash.
    • Afterward, use the needle nose pliers to insert the new needle into the needle holder securely.
  7. QSEW QS-1201 Needle Replacement: adım 7, 3 resimden 1. QSEW QS-1201 Needle Replacement: adım 7, 3 resimden 2. QSEW QS-1201 Needle Replacement: adım 7, 3 resimden 3.
    • Use the 3 mm Flathead screwdriver to secure the screw, without over-tightening.
  8. QSEW QS-1201 Needle Replacement: adım 8, 3 resimden 1. QSEW QS-1201 Needle Replacement: adım 8, 3 resimden 2. QSEW QS-1201 Needle Replacement: adım 8, 3 resimden 3.
    • Move the needle using the pliers in a circular motion from left to right to verify it moves freely without hitting any surrounding components.
    • You're all set to use your embroidery machine!
Sonuç
Reema
157 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 148
