Giriş
How to disassemble and remove the motherboard for the Qualcomm Snapdragon 800 mobile development unit.
Neye ihtiyacın var
Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
Start by disconnecting the cables attached to the motherboard
use the spudger to lift the connectors vertically off. They should pop off with relative ease
The last connector has a yellow tab. Pull up on the tab until the small metal catch lifts up. Then pull straight back to remove the connector from its socket.
Bir başkası bu kılavuzu tamamladı.
