Ana içeriğe geç
Quantum Axis A23 Camera Replacement
Neye ihtiyacın var
  1. Quantum Axis A23 Camera Replacement, Removing the Case: adım 1, 1 resimden 1.
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Camera Replacement, Detaching the Camera from the Motherboard: adım 2, 1 resimden 1.
    • Use small needle nose pliers to carefully remove the yellow ribbon attached to the motherboard.
  3. Quantum Axis A23 Camera Replacement, Detaching the Camera from the Back of the Screen: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the black tape holding the camera down.
  4. Quantum Axis A23 Camera Replacement, Attaching New Ribbon to Motherboard Slot: adım 4, 1 resimden 1.
    • Slot the new dual camera ribbon into the motherboard.
  5. Quantum Axis A23 Camera Replacement, Attach New Dual Cameras to Screen: adım 5, 1 resimden 1.
    • Attach dual cameras to the back of the screen with the black tape. Align the cameras with the designated hole in the case.
    • Fold over the camera piece so the camera are on top of each other with lenses facing out and the top as the rear.
Sonuç
Snap the rear case back on (carefully aligning the back camera with the camera hole on the case) to finish this repair.
Randy Janz
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Tanski Winter 2015 USF Tampa, Team 1-5, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 320
