Giriş
This guide demonstrates how to properly remove and replace a Quantum A23 Tablet camera in order to preserve the function of the device.
Neye ihtiyacın var
Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
Use small needle nose pliers to carefully remove the yellow ribbon attached to the motherboard.
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers to remove the black tape holding the camera down.
Slot the new dual camera ribbon into the motherboard.
Attach dual cameras to the back of the screen with the black tape. Align the cameras with the designated hole in the case.
Fold over the camera piece so the camera are on top of each other with lenses facing out and the top as the rear.
Snap the rear case back on (carefully aligning the back camera with the camera hole on the case) to finish this repair.
