Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape. Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Using a small plastic opening tool; genteelly pull the connection off of the motherboard. Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    • Remove yellow plastic and carefully pull clip away from connection.
  5. Remove yellow tape. Unclip ribbon connector.
    • Remove yellow tape.
    • Unclip ribbon connector.
  6. Unscrew plastic camera holder using a PH00 screwdriver bit. Release the plastic holder tab and remove camera.
    • Unscrew plastic camera holder using a PH00 screwdriver bit.
    • Release the plastic holder tab and remove camera.
Sonuç
stephen Munchinsky
771 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 71
