Ana içeriğe geç
Quantum XTR05 Pinion Gear Replacement
  1. Quantum XTR05 Pinion Gear Replacement, Pinion Gear: adım 1, 3 resimden 1. Quantum XTR05 Pinion Gear Replacement, Pinion Gear: adım 1, 3 resimden 2. Quantum XTR05 Pinion Gear Replacement, Pinion Gear: adım 1, 3 resimden 3.
    • Unscrew by turning the cap counter-clockwise until it is separated from the spinning reel.
  2. Quantum XTR05 Pinion Gear Replacement: adım 2, 3 resimden 1. Quantum XTR05 Pinion Gear Replacement: adım 2, 3 resimden 2. Quantum XTR05 Pinion Gear Replacement: adım 2, 3 resimden 3.
    • Remove the spool line completely by pulling it away from the reel body.
  3. Quantum XTR05 Pinion Gear Replacement: adım 3, 3 resimden 1. Quantum XTR05 Pinion Gear Replacement: adım 3, 3 resimden 2. Quantum XTR05 Pinion Gear Replacement: adım 3, 3 resimden 3.
    • Remove the gear by pulling it up and off of the pinion.
    • Replace the pinion gear with your new one by aligning the shape of the gear opening and the pinion.
  4. Quantum XTR05 Pinion Gear Replacement: adım 4, 2 resimden 1. Quantum XTR05 Pinion Gear Replacement: adım 4, 2 resimden 2.
    • Place the spool back onto the pinion.
    • Ensure that the spool is fitted properly.
  5. Quantum XTR05 Pinion Gear Replacement: adım 5, 1 resimden 1.
    • Place the spool release and drag adjustment piece back onto the top of the pinion.
  6. Quantum XTR05 Pinion Gear Replacement: adım 6, 1 resimden 1.
    • Screw the spool release and drag adjustment back into place in a clockwise direction until desired tension is achieved.
Bitiş Çizgisi
Nicholas Lynch
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 230
