Ana içeriğe geç
Quick Antenna Connection Check for Delphi MyFi XM2GO
Neye ihtiyacın var
  1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: adım 1, 3 resimden 1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: adım 1, 3 resimden 2. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: adım 1, 3 resimden 3.
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
    FixBot'a Sor
    Yorum Ekle
  2. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: adım 2, 3 resimden 1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: adım 2, 3 resimden 2. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: adım 2, 3 resimden 3.
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Quick Antenna Connection Check for Delphi MyFi XM2GO, Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 3, 1 resimden 1.
    • Under the battery is a magnetic mat, shown in red, that shields battery interference with the reception of the XM Satellite antenna.
    • This mat is stuck to the back of the device like a sticker and can be removed.
    • CAUTION: Do not operate the device without this magnetic shield.
    FixBot'a Sor
    Yorum Ekle
  4. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 4, 3 resimden 1. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 4, 3 resimden 2. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 4, 3 resimden 3.
    • On the bottom left side of the magnetic mat, the corner can be lifted up to reveal the U.FL antenna connector. A spudger or your fingernails can be used to pry up the corners.
    • These U.FL antenna connections are standard for most portable devices and WiFi cards. They may become detached through use and may be checked if no reception is present.
    • Lift up the corner and notice the two connectors going to the PCB.
    FixBot'a Sor
    Yorum Ekle
  5. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 5, 2 resimden 1. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 5, 2 resimden 2.
    • Both of these connectors must be firmly attached to the PCB. Try pressing them firmly to make sure they are making full contact.
    FixBot'a Sor
    Yorum Ekle
  6. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 6, 3 resimden 1. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 6, 3 resimden 2. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 6, 3 resimden 3.
    • On the top right corner, the magnetic mat can be lifted up to check another U.FL connector as with the 3rd step.
    • This mat can be pressed down again to secure after checking the connector.
    FixBot'a Sor
    Yorum Ekle
  7. Quick Antenna Connection Check for Delphi MyFi XM2GO: adım 7, 1 resimden 1.
    • Try pressing down on the U.FL connector, as seen in this picture, to ensure a secure connection.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Scott Byer
88 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-2, Benson Spring 2012 Clemson, Team 1-2, Benson Spring 2012 üyesi
CLEM-BENSON-S12S1G2
3 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
la radio sigue sin funcionar
luis - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 3,400
