Ana içeriğe geç
Quiksilver The Fifty50 Back Panel Replacement
Neye ihtiyacın var
  1. Quiksilver The Fifty50 Back Panel Replacement, Strap: adım 1, 2 resimden 1. Quiksilver The Fifty50 Back Panel Replacement, Strap: adım 1, 2 resimden 2.
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Back Panel Replacement: adım 2, 2 resimden 1. Quiksilver The Fifty50 Back Panel Replacement: adım 2, 2 resimden 2.
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Back Panel Replacement, Back Panel: adım 3, 2 resimden 1. Quiksilver The Fifty50 Back Panel Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Back Panel Replacement: adım 4, 1 resimden 1.
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
Sonuç
Sue Giske
622 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Liner Summer 2019 UW Tacoma, Team S1-G4, Liner Summer 2019 üyesi
UWT-LINER-SU19S1G4
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 220
