Ana içeriğe geç
Quiksilver The Fifty50 Digital Battery Replacement
Neye ihtiyacın var
  1. Quiksilver The Fifty50 Digital Battery Replacement, Strap: adım 1, 2 resimden 1. Quiksilver The Fifty50 Digital Battery Replacement, Strap: adım 1, 2 resimden 2.
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Digital Battery Replacement: adım 2, 2 resimden 1. Quiksilver The Fifty50 Digital Battery Replacement: adım 2, 2 resimden 2.
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Digital Battery Replacement, Back Panel: adım 3, 2 resimden 1. Quiksilver The Fifty50 Digital Battery Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Digital Battery Replacement: adım 4, 1 resimden 1.
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Digital Battery Replacement, Analog Battery: adım 5, 2 resimden 1. Quiksilver The Fifty50 Digital Battery Replacement, Analog Battery: adım 5, 2 resimden 2.
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Digital Battery Replacement: adım 6, 3 resimden 1. Quiksilver The Fifty50 Digital Battery Replacement: adım 6, 3 resimden 2. Quiksilver The Fifty50 Digital Battery Replacement: adım 6, 3 resimden 3.
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Digital Battery Replacement: adım 7, 3 resimden 1. Quiksilver The Fifty50 Digital Battery Replacement: adım 7, 3 resimden 2. Quiksilver The Fifty50 Digital Battery Replacement: adım 7, 3 resimden 3.
    • Remove the large circular Analog battery.
  8. Quiksilver The Fifty50 Digital Battery Replacement, Circuit Board: adım 8, 2 resimden 1. Quiksilver The Fifty50 Digital Battery Replacement, Circuit Board: adım 8, 2 resimden 2.
    • Using the Phillips #00 screwdriver, remove the two 1 mm screws holding the circuit board to the device.
  9. Quiksilver The Fifty50 Digital Battery Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the green circular chip using a pair of tweezers.
  10. Quiksilver The Fifty50 Digital Battery Replacement, Digital Battery: adım 10, 2 resimden 1. Quiksilver The Fifty50 Digital Battery Replacement, Digital Battery: adım 10, 2 resimden 2.
    • Using the Phillips #00 screwdriver, remove the 1.1 mm screw that is holding the digital battery holder in place.
  11. Quiksilver The Fifty50 Digital Battery Replacement: adım 11, 1 resimden 1.
    • Use the magnetic pick-up tool to remove the small screw.
    • Careful to not lose this screw because it is crucial for putting the watch back.
  12. Quiksilver The Fifty50 Digital Battery Replacement: adım 12, 1 resimden 1.
    • Lift up the battery holder.
  13. Quiksilver The Fifty50 Digital Battery Replacement: adım 13, 1 resimden 1.
    • Remove the digital battery from the socket.
Sonuç
Sue Giske
622 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Liner Summer 2019 UW Tacoma, Team S1-G4, Liner Summer 2019 üyesi
UWT-LINER-SU19S1G4
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 1,650
