Ana içeriğe geç
RAM memory replacement for why! W253EU
Neye ihtiyacın var
  1. RAM memory replacement for why! W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 1. RAM memory replacement for why! W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 2. RAM memory replacement for why! W253EU, Battery from why! Remove W253EU: adım 1, 3 resimden 3.
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. RAM memory replacement for why! W253EU, Access to RAM and CPU from why! W253EU: adım 2, 2 resimden 1. RAM memory replacement for why! W253EU, Access to RAM and CPU from why! W253EU: adım 2, 2 resimden 2.
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. RAM memory replacement for why! W253EU: adım 3, 3 resimden 1. RAM memory replacement for why! W253EU: adım 3, 3 resimden 2. RAM memory replacement for why! W253EU: adım 3, 3 resimden 3.
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. RAM memory replacement for why! W253EU: adım 4, 1 resimden 1.
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
  5. RAM memory replacement for why! W253EU, RAM memory: adım 5, 3 resimden 1. RAM memory replacement for why! W253EU, RAM memory: adım 5, 3 resimden 2. RAM memory replacement for why! W253EU, RAM memory: adım 5, 3 resimden 3.
    • Locate the two memory modules.
    • Release the locking spring on both sides of the module.
    • Now lift the module with its connector slightly.
  6. RAM memory replacement for why! W253EU: adım 6, 1 resimden 1.
    • Now remove the module from its connector by pulling it out symmetrically to its axis.
    • If necessary, repeat the procedure from the previous step with the second module.
    • Attention: the two memory modules must be identical, mainly in terms of their memory capacity!
Sonuç
To reassemble, follow the instructions in reverse order.
Bu çevirmenlere özel teşekkürler:
de en
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.538 İtibar
283 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 396
