Ana içeriğe geç
RCA 10 Viking Pro RCT6K03W13 Antenna Replacement
Neye ihtiyacın var
  1. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: adım 1, 3 resimden 1. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: adım 1, 3 resimden 2. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: adım 1, 3 resimden 3.
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: adım 2, 2 resimden 1. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: adım 2, 2 resimden 2.
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: adım 3, 1 resimden 1.
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: adım 4, 2 resimden 1. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: adım 4, 2 resimden 2.
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Antenna: adım 5, 1 resimden 1.
    • Identify the grey wire on the right side of the device.
  6. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: adım 6, 1 resimden 1.
    • Remove the orange ribbon cable over the wire.
  7. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: adım 7, 1 resimden 1.
    • Remove the antenna using a soldering iron.
Sonuç
Ryan Wickett
632 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G8
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Does anyone know where I can buy a new antenna for this device?
DIY_Human - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 402
