Ana içeriğe geç
RCA 8 Apollo Display Assembly Replacement
Neye ihtiyacın var
  1. RCA 8 Apollo Display Assembly Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Display Assembly Replacement: adım 2, 2 resimden 1. RCA 8 Apollo Display Assembly Replacement: adım 2, 2 resimden 2.
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Display Assembly Replacement: adım 3, 2 resimden 1. RCA 8 Apollo Display Assembly Replacement: adım 3, 2 resimden 2.
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Display Assembly Replacement, Display Assembly: adım 4, 3 resimden 1. RCA 8 Apollo Display Assembly Replacement, Display Assembly: adım 4, 3 resimden 2. RCA 8 Apollo Display Assembly Replacement, Display Assembly: adım 4, 3 resimden 3.
    • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
    • Remove the yellow tape that is around the battery.
    • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
    • If the connector is misaligned, the pins can bend, causing permanent damage.
  5. RCA 8 Apollo Display Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the three screws from the motherboard using a Phillips screwdriver.
  6. RCA 8 Apollo Display Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the battery and motherboard together from the tablet.
    • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
    • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
Sonuç
Kristen Gismondi
99.457 İtibar
255 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.639 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 79
